Sony KV-32FQ70 + Surround Sound
Discussion in 'General TV Discussions Forum' started by Spazwunkle, May 28, 2004.
  1. Spazwunkle
    Spazwunkle
    Heyhey all
    Got a new Sony KV-32FQ70, but when plugged into Surround Sound system (Sony TA-VE150) for TV viewing, only get about half volume from amp on full.
    All other Surround options work fine (DVD etc) just TV viewing. Checked leads etc all seem ok.
    Any ideas? Surround worked ok with our previous set.
    Is this a problem with the TV or a general problem?
  2. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    Hi dont know about your model but on the FX68 you have to go into setup in the menu and switch the speakers off. You then have to turn the volume back up on the tv to suit your amps input thats assuming you are using Phono leads
    hope this helps
    jaymac
  3. Spazwunkle
    Spazwunkle
    Did that, and seems to work, but if that is with all models, then its a rather over complicated way to work.
    But on a side note, messing about with it last night, and if I select Video on the amp, then you get proper volume. So I guess we'll just be using that option in the future instead of turning off speakers etc.
    Cheers for that jaymac
  4. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    Glad you are sorted it is a pain but it does also allow catering for amps of different quality/ sensitivite inputs etc.,It also allows you to use the tv.s treble/bass what have you. Not that you would want to with a decent amp. I get mine back down the scart panful but convenient
