sony KV-32FC 60E problem !!!!!!
Discussion in 'General TV Discussions Forum' started by smooth-op, Mar 27, 2003.
  1. smooth-op
    smooth-op
    Mar 26, 2003
    71
    Ashford, Kent
    i have notice the shape of the screen is distorted. the television is out of warrenty now. i hoping there is a way of setting this right. i do know how to get into the service menue but i am not brave enough to play around...
    if any one knows on how i can correct this or with the correct settings please get back to me...
    i will answer 1 thing b4 you say it. no it isnt the angle change in the normal menue as it is just a tilt to the right side of the screen.
    if you know the correct defection please get back to me
    thanks alot
    i have also attached a pic of the tv just incase you were wondering what one it is....
