Sony KV-32DX30U Help Pls
Discussion in 'General TV Discussions Forum' started by PaulBrighton, Dec 29, 2001.
  1. PaulBrighton
    PaulBrighton
    I bought the Sony TV and was told that I could record Digital Broadcasts and also watch Analogue at the same time. I can't suss this one. I also haven't had much luck in recording onto my VCR Panasonic HD650. It works ok if I have the same channel on the TV and set VCR to AV1, but timed recordings with the TV on "standby" dont always record.
    Looking at the reviews of the Panasonic DMR-E20 recordable DVD unit-this looks brillaint and would be better than VHS tapes. Would this be a "good buy" for my sony set up. I dont own any 5:1 speakers yet but would consider in the future. Can I use the DMR-E20 with this - as you can tell i'm pretty new to all this stuff. Thanks a lot if you help me out. Paul:)
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    1) AV3 is record Scart
    2) Wait for next DVD RAM recorder - DVB-T tuner is rumoured
