SONY KV-32 CS76: How to disable SVM?
Discussion in 'General TV Discussions Forum' started by Jomox, Oct 12, 2004.
  1. Jomox
    Jomox
    Aug 20, 2004
    26
    3
    Hello,
    I'm a little bit disappointed from my new SONY TV set. Although I have turned down the sharpness setting to a reasonable amount there is still some ringing effect on hard contrast lines. It always looks processed. Even movies like Monsters Inc. are looking sharpened wether sharpness is turned down or not.
    I looked at www.kv32tweak.freeuk.com and found the VM-Level setting. But in the service menu of this set I could not find anything like this.
    Maybe someone can tell me a workaround or another setting in the service menu to disable the SVM circuit. Is there any chance to get a SONY technician at home disabling this function?
    Thanks for your help!
    Greets
    Jomox
  2. mdinch
    mdinch
    Yes, I have that problem with my KD32DX200. I also haven't found out how to switch off the SVM in the service menu. However, it is possible to switch off the SVM by setting the tv into 'movie' mode. Unfortunately, you're then stuck with 'movie' settings. Then again, you could tweak you colour, contrast, brightness, etc from the service menu whilst the tv is in the 'movie' setting. :thumbsup:
    Mel.
  3. Jomox
    Jomox
    Aug 20, 2004
    26
    3
    Thanx alot! I will give it a try! :D
  4. mdinch
    mdinch
    How did you get on? Any improvements?
  5. Jomox
    Jomox
    Aug 20, 2004
    26
    3
    Yeah, it's perfect now! :thumbsup:
    I turned the set into movie mode and calibrated the greyed-out settings in the service menu. Since then a could not see any further EE artifacts. When using "A Bug's Life" all lines are natural contoured!
    Once again, many thanks for the suggestion!
    Jomox
