Sony KV-29X5U
Discussion in 'General TV Discussions Forum' started by Gaz H, May 7, 2002.
  1. Gaz H
    Gaz H
    Anybody out there had problems with the Sony KV-29X5U. My mates has just packed in with no display and the standby indicator flashing. This is listed in the trouble shooting part of the manual but it just says "contact Sony". If anyones had this fault fixed can you give me the info on it
    Gary
  2. gges
    gges
    How many times does it flash? Exact sequence please!
  3. Guest
    A common cause of this fault is dry joints on the circuit boards. My local repair shop has quoted me £46 for a complete re-solder of all the joints, doesn't sound to expensive. Its a cracking set (when Sony was Sony).
  4. Gaz H
    Gaz H
    GGES
    STANDBY LED FLASHES CONTINUALLY
    THANKS IN ADVANCE
