Sony KV 28LS35 owners in here
Discussion in 'General TV Discussions Forum' started by Tricky, Feb 16, 2002.
  1. Tricky
    Tricky
    Need some help.
    If you have this set,do you know the default settings for Geometry in the service menu?
    Doing some tweaking and dident bother to write down the defaults :(
    To get in to the service menu:
    Put tv in to standby with remote
    press info button (under No 7)
    press number 5
    press + volume
    press exit text button (under red button)
    TT comes up
    press menu
    Geometry will be highlighted press right and you see all the values.
    Could you write them down for me?
    If you can help many many thanks
    PS:this works for most new kv models,take care.
  2. simbloke
    simbloke
    'they' say that these numbers don't really have defaults, i.e. they depend on how your particular set was setup in the factory. How bad is it?
  3. Tricky
    Tricky
    ok i've got it watchable,but has a slant i cant correct in menu and slight vertical curve.I'am going to get it replaced.any ideas what the ideal settings are?
  4. simbloke
    simbloke
    Sorry, mine's gone back for good so I can't look but if one of your problems is a horizontal bowing or slant to one side (like mine had) then it can't be fixed via the service menu :(
  5. Guest
    hi,
    I have the 24 " model. Geometry horizontally is nigh on perfect, there's a slight pin cusion on one side vertically though.
    Another strange thing on my set is that horizontal centre is off, by over a centimetre. Seems strange as this can easily be fixed in the service menu.
    Here are the default geometry settings settings on my KV24LS35 if it helps;
    VL (0,63) 32
    VS (0.63) 31
    LEFT-HBLK (0,15) 11
    RIGHT-HBLK (0,15) 10
    From now on all numbers in brackets read (0,63) so I'll leave them out.
    VA 34
    VB 32
    H C 41
    HS 19
    PA 22
    UCP 14
    LCP 20
    PP 27
    VSLOPE 38
    VSIZE 14
    SC 10
    VC 10
    VZ 26
    M 35
    Can you confirm this for me; Both the top two standy by buttons on my remote are green. As this is my second set I could swear the first remote I had used to have one red button on, either the TV on, or Video on?
    cheers
    mark
