Sony KV-28FQ86 shuts off and on at random
Discussion in 'Televisions' started by ocauberg, Mar 16, 2005.
  1. ocauberg
    ocauberg
    Hi All,
    Searched this forum but couldn't find any information on the subject.
    I have a Sony KV-28FQ86, and generally speaking, it's perfect.
    But there seems to be one flaw in it though. The television shuts off and then comes on again by itself at random intervals.
    Anyone with the same problem ?
  2. ColonelK
    ColonelK
    Jan 7, 2005
    85
    Coventry
    I had a philips that did something similar. I found out it was due to the brightness level being too high, so when a white scene was displayed it shut down, then came back on again.
    I know it's probably unrelated, but you could try lowering the brightness a couple of notches and see if the behaviour disappears.
    HTH
    CK
  3. ventoboy1000
    ventoboy1000
    Hi Ocauberg,
    There is a known fault with earlier versions of this set in that they shut down randomly and the service menu is sometimes corrupted.
    I had 2 sets with this problem and both were sent back to Sony.
    Know have the KV32DX200 which im really happy with.
    Some people with this set had the software version upgraded and that seemed to cure the problem.
    Here is a link to the earlier posts.
    http://www.avforums.com/forums/showthread.php?t=138721&highlight=kv32fq86
    Hope this helps
  4. ocauberg
    ocauberg
    thanx, couldn't find a post in the forum about this problem.
    strange thing is, is bought the tv in januari... so it should have a very recent software version.
