Sony KP61
Discussion in 'General TV Discussions Forum' started by merv, Nov 6, 2000.
  1. merv
    merv
    Anyone out there help, I've got a Sony KP61 only problem is that in 16:9 mode I get distinct bands of colour from the three tubes at the top of the 16:9 image. can anyone suggest a way of getting rid of these lines also anyone know how to manually align the CRTs via the service menu.
    Thanks.
  2. Bada Bing
    Bada Bing
    Aug 8, 2001
    530
    Scotland
    +5
    I have the KP41DS1U and have recently had it modified bu Sony to allow correct NTSC playback in RGB.
    It doesn't sound like you have the same problem as 41DS1 users, but feel free to elaborate later, if you feel you do.
    To access the service menu on my model and several others, do the following.
    Put TV in StandBy
    Press 'i'
    Press '5'
    Press 'Vol +'
    Press Screen Button or TV
    Then press Menu and go to convergence.
    The main ones you'll need to tweak are:
    R,G,B H&V Skew to rotate the misaligned guns.
    R,G,B H&V Center to match up with each other.
    R,G,B H&V Size to match up with each other
    To save changes and exit service mode, press '00.
    AND BE CAREFUL!
    "Run! Go! Get to the Choppa!"
    My HC Website - Under Construction
  3. merv
    merv
    Gave it a try, I was able to access the service menu, however the service menu didn't have the suggested options within the various menus.
