Sony KP46 Rear Projector Service Menu?
Discussion in 'General TV Discussions Forum' started by Nobber, Dec 7, 2001.
  1. Nobber
    Nobber
    Nov 29, 2001
    321
    Hello
    does any one know how to get in to the service menu and save the changed settings
    thanks
    Nobber
  2. skywalker1010
    skywalker1010
    Dec 11, 2002
    280
    Hampshire
    +22
    Did you ever get the details on entering the Service Menu on your Sony Rear Pro KP46SU?.
    I have the same model and have been searching everywhere for ages for the answer to the same question.
    If anyone can help, I would be very grateful.
    Nick
  3. Nobber
    Nobber
    Nov 29, 2001
    321
  4. skywalker1010
    skywalker1010
    Dec 11, 2002
    280
    Hampshire
    +22
    Hi Nobber,
    Apologies for not thanking you earlier on your reply.
    I did see this site before it had the PAL service menu update but had not been back since.
    I have not tried it yet though as i have just bought a new Phillips 963SA Progressive Scan dvd player and have been fiddling with this.
    Do you know if the KP46SU can accept an RGB signal at 31khz?.
    I only ask as I can input the component signal through a special RGB conversion box from Keene if it can accept 31khz.
    Nick
  5. Nobber
    Nobber
    Nov 29, 2001
    321
    Sorry
    can't help there, I just use the TV for everyday use my dvd is linked to a Sony VPL11HT projector in another room, I use the RGB to Component box from keene though(till I upgrade my Sony CX850 DVD multichanger)
    Nobber
