Sony KP44PS2 Remote Control Problems
Discussion in 'General TV Discussions Forum' started by bpoostchi, Mar 28, 2002.
  1. bpoostchi
    bpoostchi
    I would like to know if anyone is having problems with the remote
    control of the above TV. My 1st TV - The remote control would not work unless I was holding the RCU 2" away from the TV. My 2nd set has started to do the same thing after a couple of months. No other TVs have shown this problem, so I doubt it is an environmental issue.
    Many Thanks
    Bernard
  2. dodocream
    dodocream
    Absolutely no problems at all with mine m8. As it's happened to two in a row, my guess is it's 'enviromental' as you put it or maybe interferance from something else in the room. Try it with nothing else electrical turned on.
    DDC
  3. Taz
    Taz
    Welcome Bernard.....
    Wouldn't this thread be better in Remote Controls:confused:
    Taz.:cool:
  4. bpoostchi
    bpoostchi
    dodocream - Thanks.
    Have tried removing some things SONY have recommended (e.g. DECT Phone, Energy Saving Bulbs, etc...), but no luck. Doubt its environmental as 2nd set behaved itself for a couple of months and now started playing up and I hven't added anything new to the room. Problem is its intermittent. Sometimes it works, sometimes it doesn't. No set pattern to it.
    Taz - Thanks :)
    I posted here as it is directly related to the KP44PS2. If you think it should be posted elsewhere, can you move it? I will gladly followup on threads in different forum.
    Regards
    Bernard :rolleyes: :
