Sony KP44PS2 or Toshiba 46WH08B
Discussion in 'General TV Discussions Forum' started by Graham Sims, Sep 30, 2001.
  1. Graham Sims
    Graham Sims
    Sep 30, 2001
    68
    Lincoln
    I'm going to buy a new TV to replace my Sony 32FX60, I would like some<br />advice please.<br />There are two rear projection tv's that I am interested in, the Sony KP44PS2<br />or Toshiba 46WH08B, the Sony looks cosmetically nicer than the Toshiba, but<br />the Toshiba has got component in, I have the Sony 7700 (region one with<br />component out), the Sony has DRC-MF, which I think is a line doubler (i'm<br />not sure) and is a bit more expensive.
    Anyone got any feedback on these TV's, I would be very grateful, as I can't<br />decide which one to buy.
    Also I don't want to get it from a "High Street" store as they are too<br />expensive, does anyone also have any recommendations for on-line or mail<br />order company's, I also need 3 years warranty, with in-home service.
    Thanks for reading.
    Graham
