Sony KP44 PS2 Owners
Discussion in 'General TV Discussions Forum' started by pi3141, Jul 29, 2002.
  1. pi3141
    pi3141
    Need your help !
    Just about to buy this model but am concerned it may have the scrolling bars as with my FQ75 & DX100 - has anyone seen them on this set ?
    Please advise
  2. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    I have never seen the scrolling bars on mine,and I'm very picky.
    Regards
  3. pi3141
    pi3141
    Cheers for your reply Simon, would appreciate it if you could check it at night on a dark background or dark DVD such as U571 / Alien etc, or even the Sony DVD menu screen / SKy digital blue screen on a radio channel (broadcasting but no picture).
    Would really appreciate it as its such a lot of money and Im tired of all this TV stuff, I just want to get the thing !
  4. Doug
    Doug
    No scrolling bars on mine either, it's not an issue with the Rear-pros, only the CRT tubes as far as I know...
  5. pi3141
    pi3141
    Thanks Doug, I certainly havent heard of anyone complaining about them on this set but I had to make sure !
    So are you pleased with this set in general ? - would you recommend it ?
    thanks
  6. Doug
    Doug
    Definitely,great picture,looks good which is important since it will take up a big part of your room
    Just make sure that yr dealer sets it up correctly on delivery, do a search on KP44PS2 on these forums to familiarise yrself regarding the various issues re setup, ie convergence, geometry, etc
  7. pi3141
    pi3141
    Thanks Doug, just ordered it, got it for 2k inc delivery and setup. Putting it through my Sony1070 Amp so cant wait. Will search these forums for setup advice.
    Using it for Sky digital, DVD and the odd PS2 session.
