Sony KP-53XBR45 R/P TV Question
Discussion in 'Projectors, Screens & Video Processors' started by mikedem, Mar 16, 2003.
  1. mikedem
    mikedem
    I have a Sony KP-53XBR45 R/P TV from 1997. I read somewhere that it's scan is progressive. Is this true? Does this mean that it converts incoming signals to Progressive Scan?
    I'm asking because I want to purchase a DVD Recorder, Toshiba RD-X2 which does not support Progressive Scan. Will my Sony TV convert it's signal? Or should I settle for a DVD Recorder that does Progerssive Scan?
    I want to get away from VHS.
    Any help would be appreciated.
  2. bxd
    bxd
    Oct 17, 2001
    1,487
    Southampton
    +134
    As far as I'm aware, the Sony XBR series are North American and not european / UK models. You might be better asking your question over on the AVScience Forums.
    brian.
