Sony KP-41DS1U
Discussion in 'General TV Discussions Forum' started by Radial, Oct 14, 2004.
  1. Radial
    Radial
    Hi, I recently purchased a Sony KP-41DS1U through ebay, trouble was there was no users manual, I am now doing an auto search but after it sorts out the freeview channels it keeps flash ing sorting and remains on --- DIG C 50 --- It's now been doing this for over one hour, if I stop it as I did on a previous auto search it do not include any analogue channels and fails to find many freeview channels including most radio channels, any idea what I may be doing wrong.
    And more importantly any idea wher I may get hold of a users manual, I have contacted Sony but as yet had no reply from them.
  2. mrtbag
    mrtbag
    Dec 17, 2002
    3,658
    Anywhere I want
    +394
    Here is a link to the 51 inch. Should be the same.
    KP51DS1U
  3. Radial
    Radial
    The Link you gave is not working ?
  4. mrtbag
    mrtbag
    Dec 17, 2002
    3,658
    Anywhere I want
    +394
    Try it again, I have edited the link.
  5. Radial
    Radial
    Thanks it's okay now, looks like a long and interesting read :thumbsup:
  6. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    These use the same tuner as my DX20 - basically it can't allocate all the channel.
    What you need to go is manually tune in the radio channels - find the list on the internet somewhere with a search engine.
    Don't need the analogue :p
    Then remove the TUTV junk by changing source from DIG to -
    Manual tuning is in the book.
    Please tell us what software you have by looking on the EPG
