Sony KLVL32M1
Discussion in 'Sony TVs Forum' started by jacksoag, Dec 14, 2004.
  1. jacksoag
    jacksoag
    Am intending to buy this model after the Xmas rush is over (if there's any left in the country.........) and would be interested in the opinions of any current/new owners. Is it as good :clap: as various ' Best Buy' reviews are claiming? :smashin:
  2. sonysideup
    sonysideup
    Nov 23, 2004
    hi
    i was in the same boat but i've been a little put off by the high definition problem. the sony only supports component inputs whereas sky's high-def broadcast requires either dvi or hdmi. the guy in the sony centre believes this will be sorted out but having seen the views on this forum, i have my doubts. i'm keeping my powder dry until everything settles down. that said, if they can find a solution, i will buy this set - every review says it's superb
  3. dmdeev
    dmdeev
    According to Sony' s site the american version of this model has an hdmi input. It seems that they think Europeans don't need hdmi. :mad:
