Sony KLV-L32M1
Discussion in 'Sony TVs Forum' started by thedandydon, Jan 12, 2005.
  1. thedandydon
    thedandydon
    Can anyone help..I'm thinking of buying the Sony KLV-L32M1 lcd tv..but i'm getting conflicting stories to whether it is HDTV compatible or not.
    All comments gratefully received. :confused:
  2. jimg
    jimg
    Jul 4, 2004
    826
    +58
    A set may be marked HDTV compatible and it means it is capable of displaying a HD image. The problem comes when you look at where the source of your HD image may come from. HD broadcasts in the UK from SKY will be output via HDMI and this means your TV must have a HDMI input or a DVI input that supports HDCP protocol. It is probable that future HD DVD players will incorporate this technology as program producers demand protection of their material.
    Have a look at this thread:-
    http://www.avforums.com/forums/showthread.php?t=176212
  3. thedandydon
    thedandydon
    thanks jim for your reply...one other question if you don't mind my ignorance on this matter..if this set is capable of displaying a HD image, where would that source come from if this set doesn't have the HDMI or DVI inputs.
  4. thedandydon
    thedandydon
    Thanks for your replies... :thumbsup:
  5. jimg
    jimg
    Jul 4, 2004
    826
    +58
    Possibly via component ( then it's analogue not digital ) and a DVD player that can upscale? Not sure really! :confused:
  6. domtheone
    domtheone
    Nov 23, 2004
    14,770
    Nottingham
    +3,551
    You can get HD via the component inputs, sasy from a D-VHS player or future HD DVD player (assuming they come with component inputs)
  7. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    The Sony you are looking at is incapable of displaying HDTV broadcasts. Proper High Definition broadcasts can only be input via DVI or HDMI inputs.
    If the set has component inputs it is possible that it can display High Def inputs from some DVD players.
    Jimmy
    Sorry, domtheone, we just answered the same question at the same time!
    Jimmy
  8. domtheone
    domtheone
    Nov 23, 2004
    14,770
    Nottingham
    +3,551
    That's ok, glad to have the backup ;)
