Sony KLV-L32M1
Discussion in 'LCD & LED LCD TVs' started by d'vo, Dec 7, 2004.
  1. d'vo
    d'vo
    I went to a local branch of Alders (of all places), and happened to catch a glimpse of the new Sony KLV-L32M1 and immediately fell in love. It seemed to produce the best image quality of the all the LCD machines on show by far - even though the Philips 32PF9986 and another Sharp 32" model (I've forgotten the exact model number), were playing directly feed DVD pictures (these were my previous hot favourites) - and the Sony was at a disadvantage by showing Shrek2 via some shared feed, and it still blasted them fair and square.
    Now, this forum has been suspiciously quiet about the Sony KLV-L32M1 - perhaps a little too quiet. Have I missed a trick? The price seems to be right at £1700. I know it doesn't have HDMI/DVI etc which I am very annoyed about Mr Sony sir (especially as you gave it to the folks in the Good 'ol US of A) - but I think I can just about live without it.
    My question boils down to this: has anyone got one up and running. Have any niggles come to light? Would anyone recommend over the obvious competitors e.g. Philips, Sharp & Toshiba? What is it like with those poor Sky/NTL channels?
  2. spergabite
    spergabite
    Jul 23, 2004
    46
    I have also been very impressed witht his TV. I too share your opinion that it is the best quality. Bear in mind that the DVD source is probably excellent. ie a high bit rate well mastered modern dvd disc. Stick on a ropey old film and im sure it will start to fail, like most LCD's...
  3. Cal
    Cal
    I did loads of research, viewed every model at least twice in different stores with different sources etc etc.
    LCD close up sucks compared with CRT, but when you get 6 feet away it is great.
    The Sony KLV-L32M1 was the best one in my opinion - the sharp looked washed out - the panasonic styling is a bit too "dixons" and the colours were not great, the toshiba was really washed out.
    I am very happy with it on my Sky+ box via RGB scart. Paid around £1650 and another £399 for a 5 year warranty - it's new technology so no-one knows what the long-term reliability will be.
    On DVDs via component the picture sharpens further and is great.
    On the X-Box via the component AV cable adapter it is also brilliant.
  4. d'vo
    d'vo
    Thanks Cal. Any idea of the response time? Is there any motion blur/ghosting with your Xbox?
  5. Cal
    Cal
    Sorry have not checked back sooner.
    No ghosting on XBox - the picture from the XBox seems to be the clearest of any of them...
    The only drawback is the component rather than HDMI for HD signals. However that is a disadvantage based on a maybe promise from Sky of HD in 2006 over protected HDMI only. Based on Sky's other launches don't hold your breath
  6. Hobo4
    Hobo4
  7. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    May be a good picture - slightly lacking in contrast. However, think carefully before buying this set. NO COMPLIANCE WITH HIGH DEFINITION....at all!
    Sony need a kick in the ........ It's also not very pretty....
    Jimmy
  8. jrs
    jrs
    Jan 2, 2005
    11
    3
    Oslo, Norway
    +3
    How can you say that it doesn't have any HD compliance?
    Shouldn't a resoultion of 1366x768 be enough?
  9. domtheone
    domtheone
    Nov 23, 2004
    13,678
    Nottingham
    +2,393
    He's probably talking about HD on Sky. See cals post.
  10. CLH
    CLH
    Apr 15, 2002
    2,126
    38
    +21
    It won't comply with Sky.
    Also it's likely that all HD might well need HDCP encyption. That can't be done over component only DVI/HDMI (unless you can find a non DVD forum player).
    That being the case the Sony is NOT HD compliant. A huge stumbling block.
  11. Garp
    Garp
    Feb 15, 2005
    28
    4
    London
    Not very pretty eh?
    I think we all are allowed and must have different opinions,
    as I happen to think I looks a class above the rest.
    (apart from the other really expensive sonys)
