Sony KLV-L32M1 can Component input be converted to dvi/hdmi
Discussion in 'Sony TVs Forum' started by spergabite, Oct 18, 2004.
  1. spergabite
    spergabite
    Jul 23, 2004
    46
    Ive got my eye on this tv in debenhams - its going for £2030 including a free sony dvd recorder and 3 years warranty and also 24 months interest free credit - most tempting however it only has rgb s-vid and component - it says that it is hi def compatible however will i able to input/converter a dvi into the component inputs - i think the answer is no but i would like some confirmation if anyone knows... thanks in advance
  2. Rob20
    Rob20
    Jul 3, 2004
    3,107
    +665
    Sorry, I'm a bit confused. What connections have the dvd and tv got. Can you explain again how you'd like to connect the dvd to tv. :confused:
  3. spergabite
    spergabite
    Jul 23, 2004
    46
    future dvd player will have hdmi or dvi - lcd tv has component inputs...
  4. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    future DVi players will have component inputs too, the process would involve u converting an analogue component signal to digital.
    u might as well stick with component
  5. Rob20
    Rob20
    Jul 3, 2004
    3,107
    +665
    I can see absolutely no point in buying a dvd player with a digital video output, (hdmi/dvi), only then to buy an lcd/plasma that only has a component input. The whole point of having a digital video connection is that it removes the need to convert the signal from digital - analogue - back to digital, (which you want to avoid as this will result in an element of picture degredation). As component only carries an analogue signal, this is exactly what would have to happen. With an hdmi lead the path is digital from your dvd player to your lcd/plasma.
    It seems to me that almost all the upcoming new lcd tvs will have hdmi or dvi. Unfortuantly I was unaware of this when I bought my Tosh 26" wl46 a couple of months ago. If I'd known I'd certainly have waited for a digital connection. Look at Toshiba's new 32" WL48 set for less than £1,300. Or if you're the patient type, wait till 2005 when Sony's bound to have a new range of sets with the digital video connection.
