sony kl50w2 picture problems
Discussion in 'Projectors, Screens & Video Processors' started by richie44, Apr 26, 2002.
  1. richie44
    richie44
    Ive searched for other posts on this problem,but still none the wiser,hope someone has any new ideas.
    Sony KL50W2 LCD Rear Projection TV
    I bought this new 18 months ago and upto last week the picture was great.I switched on one morning and was shocked to see on the bottom right of the screen a defused purple/pink patch,which made any white or grey image turn pink when in that screen area.
    Well this week ive noticed the pink/purple area is getting bigger and also a green patch has appeared on the top center,like a stripe.
    If i turn the colour down to black and white its still there,also i removed the the aerial and the scarts so nothing connected,so i show just a no signal picture noise and its still there.
    Its out of waranty now,so has any one any suggestions
  2. richie44
    richie44
    Sorry i forgot to say that i removed the bulb and and carefully cleaned it and removed a panel on the side to access the lens and cleaned with a lens cloth in case it was a dust problem,but no luck
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,614
    Somewhere in South Yorkshire
    +6,156
    Could be dust particles in the LCD block. I never had mine apart, myself, but I watched an engineer do it. I can't offer any guidance as to how to get to it, but a thorough blow clean with an engineer's air blower may clear it.
  4. richie44
    richie44
    Regarding previous post.....
    I thought i would try and solve this picture problem myself and have a look inside,now i wasnt going to get too involved,just that i might see something i could fix myself(dust).
    I removed the 2 side panels and cleaned the lens with the correct clothe,the mirror looked spotless so left alone,swithed on and still this pink place was still there.
    Next i removed the whole screen from the main unit and what i could see i wouldnt want to tamper with it too much.
    I looked at the mirror again and found the problem,it was covered,not with dust,but a film of grime,so i removed it and gave it a good clean(u wouldnt believe the crap that came from it),re assembled everything and switched on........ITS CURED...what a fantastic picture ive got now,pin sharp images,vivid colours,the dogs b*****ks,wasnt even like this when it was new 18months ago........The thing is,when u remove the 2 side covers to view the mirror,because its faces down at an angle it does look clean,its not till its removed and u see it in the light,you then see how clean it is.
