Sony KF-50SX300
Discussion in 'LCD & LED LCD TVs' started by corrupthalo, May 8, 2005.
  1. corrupthalo
    corrupthalo
    May 8, 2005
    15
    Hi I have just bought a new Sony KF-50SSX300 from Curry's not very cheap I might add. It was delivered on friday there and the 50" tv is a bit big for the room but i will make do...
    The question I have is when I watch the tv either on sky+ on dvd occasionally I notice that the picture will freeze for a fraction of a second and then it will be ok again. This can be quite annoying as it can last for a few minutes.
    Is this a feature of rear projection tv's? If so I suspect that the tv will be crap at displaying my beloved liverpool this afternoon against the arse, so the tv could be going back proto...
    Is the problem caused by something that I am doing?
    Cheers for all your help....
  2. Razor
    Razor
    Dec 15, 2004
    37,545
    2
    +12,498
    Hi corrupthalo, welcome to the forums :)
    This isnt normal for rear pro viewing. I would report this issue asap. Did you not look into DLP rear pro technology.
    For more info on DLP rear pro:
    http://www.avforums.com/forums/forumdisplay.php?f=165
    All DLP sets are HDTV in resolution.
    I hope you get this issue sorted soon. :smashin:
  3. corrupthalo
    corrupthalo
    May 8, 2005
    15
    No I did't I accepted what I was told as you would..............
    Are you saying this is normal for lcd t
    v?
  4. Razor
    Razor
    Dec 15, 2004
    37,545
    2
    +12,498
    No this isnt normal for LCD rear pro viewing, get an engineer out asap.
    I was just pointing out that you could of got a better set for the cash. These 50' sony lcd rear pros have a bit of a bad rep.
  5. corrupthalo
    corrupthalo
    May 8, 2005
    15
    looks like tv going back and getting refund....
    what lcd set should I get next...
    answers on a postcard please
