buzlightyear
Ive got a modded Pal Xbox with the MS Hi def pack and the enigmah video switcher, ive enabled 480p Prog scan in the MS Dashboard and NTSC in the Video switcher and loaded up some games. The screen displays 480p in the corner but the quality looks awful, jagged lines and all i can describe as lines which look like they are running down the screen in the background. I enabled 720p but i dont think the games i have run in 720, im using PGR2 and NFS Underground, but the image is a bit better but i dont get the 720p displayed on the screen. The same happens with my Jap Gamecube with the Nintendo Digital cable. My denon 3800 DVD player seems fine when running in Prog scan. Anyone got any ideas of what im doing wrong? or how to fix it?
Buzz...
Buzz...
