Sony KE-32TS2E
Discussion in 'Plasma TVs' started by mcanoe, Jan 12, 2005.
  1. mcanoe
    mcanoe
    Hi All,
    I'm trying to connect a PC, (VGA out), to Sony KE-32TS2E without a signal converter.
    Apparently the TV accepts VGA signals, I'm assuming via the RGB, (Y/G, PB/CB/B, PR/CR/R), jacks...
    Does anyone know if this is right and if so what lead is required.
    Many thanks for any help with this as it's got me beat!
  2. fatty 99
    fatty 99
    Nov 23, 2003
    137
    i have got the 42" version and i want to know if it can do 720p through component for the xbox 360.
  3. mugsy
    mugsy
    Nov 1, 2002
    668
    Kent
    +20
    You need a VGA to RGBHV cable - they usually have BNC connectors so you would then need BNC to phono adapters to connect to the Sony. You can probably get a cable and adapters from ebay for £10 or so. If you hunt around you should be able to find a cable with phono connectors to go straight into the Sony although it may be a bit more expensive.
    It can indeed accept 720p through the component inputs - not sure if it's 50/60hz or both however - will try and dig out the manual to check.
  4. fatty 99
    fatty 99
    Nov 23, 2003
    137
    thanks mugsy
  5. fatty 99
    fatty 99
    Nov 23, 2003
    137
    got samsung hd850 dvd player and played 720p 50hz ,could not get a
    picture but 60hz ok .what i want to know is,will pal xbox 360
    do 720p 60hz and what about sky hd box.
  6. mugsy
    mugsy
    Nov 1, 2002
    668
    Kent
    +20
    Nothing in the manual about which resolutions/refresh rates it can handle (I'm sure I've seen it somewhere though).
    Looks like we might be buying new plasma's :rolleyes:
  7. fatty 99
    fatty 99
    Nov 23, 2003
    137
    so it looks like a visit to bank manager :D
