Sony KDS-55A2000 &pC input
Discussion in 'General TV Discussions Forum' started by Rip, Apr 26, 2007.
  1. Rip
    Rip
    Aug 30, 2004
    557
    Trowbridge
    +42
    Has anyone managed to get their pc connected through vga to their set & have it full screen yet ? I have been trying also with power strip & still cannot get the pic to fit the whole screen, anyone ?
  2. NicolasB
    NicolasB
    Oct 3, 2002
    6,686
    137
    Emily's Shop
    +1,068
    Can't be done. You'll need to use the HDMI input, not VGA.
  3. Divide by zero
    Divide by zero
    Dec 28, 2006
    1,590
    +91
    Has anyone talked to Sony about this?
    Surely something could be done with a firmware update?
  4. NicolasB
    NicolasB
    Oct 3, 2002
    6,686
    137
    Emily's Shop
    +1,068
    I wouldn't bet on it. The 55A2000 is not the only Sony TV to have this limitation. Indeed, the american version of the 55A2000 doesn't even display a picture for any VGA input resolution above 1366x768. I don't think VGA is a priority for Sony. (Maybe it's their way of trying to get you to buy a PS3 instead of an XBox 360?)
  5. Rip
    Rip
    Aug 30, 2004
    557
    Trowbridge
    +42
    Damn sony the f*%$*ers, dirty good for nothing chicken pluckers. But if anyone has anymore info on it plz share it with us....:thumbsdow
  6. Divide by zero
    Divide by zero
    Dec 28, 2006
    1,590
    +91
    I have both, but I hear that the 360 will upscale DVDs via the VGA.
    If Sony would hurry up and make the PS3 upscale then I would be a bit happier, though my HD-DVDs will still be at 1080i :(
  7. valledd
    valledd
    Hi folks,
    Would a HDMI-DVI cable between the screen and pc work effectively? I'm considering purchasing the 55" Sony and my video card has a DVI socket but i'm not sure if it will "hand shake" properly.
    Cheers,
    Dan
  8. NicolasB
    NicolasB
    Oct 3, 2002
    6,686
    137
    Emily's Shop
    +1,068
    Yes.
  9. AndyCob
    AndyCob
    May 3, 2005
    1,917
    +281
    It's possible that this is not true but I read the reason for the sub full screen picture by VGA is because the set is a rptv there is a certain amount of optical overscan. The decision was therefore made that because a VGA input would be from a PC and people wouldn't appreciate parts of the desktop such as the taskbar being off the screen so the picture is scaled down to ensure the whole desktop is displayed. The assumption being that a video input where you wouldn't be concerned by the small overscan would be sent by HDMI.
  10. derthballs
    derthballs
    Sep 13, 2004
    276
    +11
    I doubt that is true, its not like its just a small amount of black borders, its almost half and half:thumbsdow
  11. Rip
    Rip
    Aug 30, 2004
    557
    Trowbridge
    +42
    I have tried DVI - HDMI to the set & its even worse, i will try a few other things. Has anyone got this to work yet ?
  12. Tarbat
    Tarbat
    Oct 15, 2003
    2,590
    Easter Ross, Scotland
    +302
    WOrks okay for me. In what way is it "even worse"?
  13. Rip
    Rip
    Aug 30, 2004
    557
    Trowbridge
    +42
    Hey Tarbat, sorry i didnt answer your post i was busy & didnt get back to read the thread, i will try it again tomorrow & post my results, cheers :thumbsup:
