Sony KDLV32A12 freeview recording problem
Discussion in 'LCD & LED LCD TVs' started by mgicu, Sep 22, 2005.
  1. mgicu
    mgicu
    Received my V32 last week, and I think it's fantastic. Great PQ via my Pioneer 575 on component, and much better freeview reception than via my previous philips box.
    I do have a problem, however:
    When I choose a program to record using the EPG, it does not always switch to the required channel. If the TV is on, everything works fine. If the TV is on standby (with the timer light on), the TV activates my HDD recorder at the correct time, but often records the last channel that I was watching, not the one I want. Sometimes it does switch, but most of the time it doesn't. I have switched the AV2 output to Digital TV from Auto, in case it was this, but the problem seems to be with the tuner.
    Interestingly, if I set the timer up manually (by setting date, time, channel etc.), then it (so far at least) seems to work.
    Has anyone else experienced this, and can anyone offer any advice?
    Sounds like it may be a software bug, but goodness knows!
    :lease:
