Sony KDL40X3500 or 40W4500
rlynch53
I was wondering if anyone can point me in the right direction, I am about to purchases one of the above and was wondering if there is much difference between the two and which would be the better buy.
cheers :thumbsup:
ChrisGgr
the new W4500 is a clearly better choice.way better blacks,very improved motion and cheaper
Danstable
I am having to make the same decision and am in the position where they both cost almost exactly the same amount. Would you still go for the 4500?
What does X do better than W?
Is the 3500 about to be replaced?
So many questions, so little time!
Help!
ChrisGgr
the X3500 is discontinued and practically has no advantage,so still the W4500
Craig uk
X looks way better switched off, and really only loses out on black levels in operation.
audiphile76
W4500 has better blacks than Panasonic Plasmas and also are plasma beaters at detailing. LCD technology at its best ever :thumbsup:
⭐ Philips OLED908 TV & Musical Fidelity A1 amp reviews + a look at two home cinema speaker packages
Back
