Hi,I've got the sony w4000 and would like to know if i should enable the full pixel setting? I have tried it but when i do, on sky down both sides of the screen i get thin black lines,when i do this with my blu ray player there is no black lines.Am i doing something wrong or is this normal.
This should be in the LCD forum rather than the plasma, technically.
However, the general guide with "full pixel", "just scan", "dot-for-dot" settings etc, is to engage them with all HD content, and also standard definition DVD if possible in your set up.
I assume when you're talking about Sky you're referring to Sky HD set to 1080i, but viewing an SD channel? This is understandable. I guess it's up to you really. Though you may find you get best results for SD programming via RGB Scart.
