Sony KDL40W2000U and Xbox 360
Discussion in 'Sony TVs Forum' started by Mike191272, Apr 30, 2007.
  1. Mike191272
    Mike191272
    Mar 3, 2006
    55
    St. Helens
    Hello everyone
    I've got a Sony KDL40W2000U TV and have it connected to my Xbox 360 via the VGA cable. Via the 360, I have set it up to 1080p but I am no expert so I am not 100% sure!! When I first switch the 360 on, I get a message saying "Unsupported Display Format" - this is in the PC input mode. The colours also look a little washed out - I don't think that this is the famous clouding issue as the TV in SD mode looks excellent.
    Am I doing something completely wrong?
    What can I do to make the colours more vivid via the 360?
    Can anyone else tell me what settings they have for this TV and the 360??
    Like I said before, I am no expert so layman's terms would be good!!!!
    Thanks in advance
    Mike
  2. kulter
    kulter
    Sep 24, 2006
    34
    can't help you with the resolution 'cause I have a 720p tv and my resolution via VGA is 1360*768.I suppose your tv can handle 1080p via vga, if not sure though read the manual.
    As for the washed out colors just turn the brightness down a bit and turn the color up. It worked for me on my sammy r series. It will never have as vibrant colors though as component, but I actually prefer it like this :D
  3. eternaldark
    eternaldark
    Oct 23, 2004
    1,410
    Inverness
    +62
    Firstly the message applies to all of us with the telly, just press a button on the remote and it will go away.
    I think there is going to be a dash update (sure its the May 7th one)which address's the vga colour issue but in the meantime just turn the colour up etc.
