Sony kdl40v3000 TV
Discussion in 'Sony TVs Forum' started by MURFIA, Feb 3, 2014.
  1. MURFIA
    MURFIA
    Jan 2, 2007
    24
    Hi all,
    I have a Sony kdl40v3000 TV with a RMT-B102P controller. The controller turns the TV on, the mute and volume also works. The other buttons do not. I have viewed the controller through a camera and the LED lights up with all the buttons. I have also opened the controller and it appears to be clean. I’m guessing it may be a faulty TV receiver? If so is it easy to test/swap?
    Thanks.
  2. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    Thread moved
    Curly
  3. JayCee
    JayCee
    Jan 20, 2004
    23,764
    Lanarkshire
    +2,572
    That remote control model you have is for a Sony Bluray player and is only designed to operate the basic functions of the Tv as you've discovered.
    There is nothing wrong with the IR receiver in your Tv...it just requires use of the correct remote control.
  4. MURFIA
    MURFIA
    Jan 2, 2007
    24
    Thought it was odd that when I looked for a new remote, it was titled Bluray remote.
    The TV was given to me, so I'll look for replacement.
    Thanks for the conformation.;)
