Sony KDL32V200U Power consumption
Monk888
Looking to purchase a Clearer Audio mains power cable (yes they work and sharpen the picture, honest I was a doubter)
They have asked me which fuse I want fitted, the Sony free plug comes with a 13A fuse.
The TV draws 14.5W and supplied by 240V, which equates to .06Amps, can't beleieve this is correct, what fuse amp should I fit. I phoned Sony UK and they were technically confused!
I phoned Pioneer about my 989 and they stated it should be fine with a
5 Amp fuse. Shows Pioneer take customer support seriously.
Back to the Sony LCD, any advice or should I stick with a 13A fuse
Thanks,
Mike Paul
dave7
NX3 did you measure the power consumption in standby and off as well?
I have just bought a 32v2000 and have measured the following:
Backlight full (No powersaving) 146 watts
Backlight 3 (No powersaving) 108 watts
Backlight 3 (powersaving low) 77 watts
Backlight 3 (powersaving high) 62 watts
Standby 1 (straight way) 24 watts
Standby 2 (after about a minute) 10 watts
OFF 10 watts
the last two results are considerably higher than the sony spec says.
Similar threads
