Sony KDL32S2530 - DVI > HDMI problem..
Discussion in 'Cables & Switches' started by dvk, Sep 17, 2007.
  1. dvk
    dvk
    Aug 29, 2007
    52
    +5
    Hi guys,
    I recently set up my PC to connect to my amp (Sony STR-DA1200ES) with a DVI to HDMI cable. Then I have HDMI from the amp to my TV. The picture came out very strange, looked as though each alternate horizontal line was missing/corrupt, basically a very poor picture. I set the resolution of the PC to 1368 x 760 to see if that would make any odds. Should I try setting it to 1920 x 1080? Not too clued up on these things,
    Any advice would be welcomed,
    Cheers,
    dvk
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,724
    The Borders
    +3,513
    Hello dvk
    PC's and HDMI Inputs on Displays and AV Receivers are not always the best partners.
    The HDMI Input on the AV Receiver will likely only work with a limited range of 'Video' Resolution signals (480p, 576p, 720p, 1080i and possibly 1080p) - its unlikely to support any 'PC' resolution signals.
    Have you connected the PC direct to the HDMI Input on your Display to find the optimal settings for the Graphics card - you may find its better to not go via the AV Receiver with your PC.
    Joe
