Sony-KDL32D3000
Discussion in 'Sony TVs Forum' started by tony_ montana, Sep 8, 2007.
  1. tony_ montana
    tony_ montana
    Hi peeps,need help with the Sony-KDL32D000,noticed when playing games on my xbox360 Elite using HDMI I've noticed an odd ghosting effect with this tv,if anyone can post up what settings they are using thanks.
  2. Dandy11
    Dandy11
    what games were you playing?
  3. tony_ montana
    tony_ montana
    Hi m8 Bioshock,Medal Of Honor Airborne.
  4. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    Is Noise Reduction turned On? If so, make sure it goes Off :thumbsup:
  5. tony_ montana
    tony_ montana
    yes its off m8,here are my settings
    picture mode-standard
    back light-3
    contrast-80
    brightness-50
    colour-50
    colour temperature- neutral
    sharpness-min
    noise reduction-off
    mpeg noise reduction-off
    black corrector-off
    adv contrast enhancer-low
    gamma-low
    clear white-low
    live colour-low
    colour space-wide
  6. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    Maybe the odd ghosting effect you've mentioned is the Motion Enhancer - I can't remember off hand where that is in the menu in this TV, but turn that Off?
  7. tony_ montana
    tony_ montana
    That is off m8, using the game mode,when using the game mode u can't use Motion Enhancer anyway.
