Sony KDL26U3000 - any owners? any good?
Discussion in 'Sony TVs Forum' started by Nice Swan, Jan 25, 2008.
  1. Nice Swan
    Nice Swan
    Nov 19, 2006
    108
    19
    This is currently £200 off in Sainsburys for £349.
    Just wondering what its like.
    Heres a link to the spec....
    http://www.dabs.com/productview.aspx?quicklinx=4Q1D&CategorySelectedId=11229
    Freeview Built In
    Yes
    HDMI Inputs
    2
    Aerial
    Type
    None
    Audio System
    Features
    Auto volume adjustment
    Output Power / Total
    20 Watt
    Sound Effects (JA)
    BBE ViVA HD3D
    Virtual Dolby Digital
    Sound Output Mode
    Stereo
    Speakers Included
    2 speakers
    Surround Mode
    Built-in
    Battery
    Type
    None
    Digital Storage Media
    Type
    None
    Dimensions & Weight
    Comments (JA)
    Without stand
    Depth
    12.1 cm
    Height
    45.3 cm
    Weight
    10 kg
    Width
    65.7 cm
    DVD
    Type
    None
    Header
    Manufacturer
    Sony
    Model
    KDL-26U3000
    Product Line
    Sony
    Miscellaneous
    Colour
    Black
    Power Device
    Form Factor
    Internal
    Power Consumption Operational
    90 Watt
    Power Consumption Stand by / Sleep
    0.7 Watt
    Type
    Power supply
    Radio System
    Type
    None
    Remote Control
    Technology
    Infrared
    Type
    Universal remote control
    Remote Control (2nd)
    Type
    None
    Stands & Mounts
    Stand Design
    Tabletop
    Stand Included
    Built-in
    Television
    Analogue Video Input Signals
    NTSC 3.58
    NTSC4.43
    PAL
    SECAM
    Audio Controls
    Sound mode
    Brightness
    450 cd/m2
    Clock / Timer
    Yes
    Comb Filter
    Digital
    Diagonal Size
    26 in
    Diagonal Size (cm)
    66 cm
    Digital Television Certification
    HD ready
    Display Format
    720p
    Display Menu Language
    Bulgarian
    Czech
    Danish
    Dutch
    English
    Finnish
    French
    German
    Hungarian
    Italian
    Norwegian
    Polish
    Portuguese
    Romanian
    Russian
    Slovak
    Spanish
    Swedish
    Turkish
    Dynamic Contrast Ratio
    5000:1
    Features
    Channel labeling
    Live Colour Creation
    On-screen menu
    Parental control
    Video noise reduction
    HD Ready
    Yes
    Image Aspect Ratio
    16:9
    Image Contrast Ratio
    800:1
    Input Video Formats
    1080i
    480p
    576i
    576p
    720p
    LCD Backlight Technology
    Wide Color Gamut-CCFL
    Parental Channel Lock
    Yes
    PC Interface
    VGA (HD-15)
    Picture Adjustment
    Vivid/Standard/Movie
    Pixel Response Time
    8 ms
    Progressive Scan
    Progressive scanning (line doubling)
    Resolution
    1366 x 768
    Series
    BRAVIA
    Technology
    TFT active matrix
    Timer Functions
    Sleep
    Standby
    Wake
    Type
    LCD TV
    Video Interface
    Component
    Composite
    HDMI
    S-Video
    SCART
    Viewing Angle
    160 degrees
    Viewing Angle (Vertical)
    160 degrees
    Widescreen
    Widescreen
    Widescreen Modes
    Auto Wide
    Conventional 4:3
    Wide
    Zoom
    Zoom 14:9
    Zoom 16:9
    TV Tuner
    Analogue TV Tuner
    PAL
    SECAM
    Channel Coverage
    Cable:1-20
    Cable:21-41
    UHF:21-69
    VHF:2-12
    Digital TV Tuner
    DVB-T
    Electronic Programme Guide
    Digital EPG
    NexTView
    Reception System
    PAL-B
    PAL-D
    PAL-G
    PAL-I
    PAL-K
    SECAM-B
    SECAM-D
    SECAM-G
    SECAM-K
    SECAM-L
    Stereo Reception System
    NICAM
    Teletext
    Yes
    Teletext Memory
    700 pages
    Tuners Configuration
    1x analogue/digital combo
    TV Tuner Presence
    Built-in
  2. gobstopper
    gobstopper
    Dec 13, 2004
    552
    28
    +69
    Maybe this will help.
    My brother bought one of these to replace his dead CRT, was in a hurry and on a fairly tight budget.
    Seeing them in store, and connected to a shared aerial feed it was surprising to see just how good the picture actually was. Not top notch, but perfectly decent.
  3. Nice Swan
    Nice Swan
    Nov 19, 2006
    108
    19
    I was all set to buy an LG 26LC2R then I saw this in Sainsbury's and now I dont know.
    :lease:
  4. Sanj250
    Sanj250
    Jun 2, 2004
    105
    +3
    I bought one, took it back after a couple of days, picture quality was awful.
  5. markey
    markey
    Bought one of these for the bedroom. Ok as a second TV but wouldn't want it in my living room. After a bit of fiddling managed to get a reasonable picture.
  6. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    It has a cheap TN panel.So avoid it
  7. samperry209
    samperry209
    Mar 30, 2008
    4
    im a owner
    and funny enough got it from sainsburys
    now i got this for 1 reason
    i hate a rubbish old hitachi tv that didnt do my ps3 any justice!
    so i nipped down to sainsburys and with 2 mins brought it!
    the good things bout this tv:
    Hd up to 1080i output
    freeview inbuilt
    doesnt take up loads of space
    great with ps3 (recommend getting hd lead tho)
    now bad bits :(
    hardly any but 1 othing it took while getting freeview channels (but thts is because i cant get freeview channels without a booster!)
    other than tht its a awesome telly
    and perfect size as i got it for my bedroom
    because that is no point getting a 40 inch for your bedroom because you will only blind yourself!! but this will not happen if you have a massive bedroom and i mean massive
    i went by playstation magzine recommendations for size of telly for size of room
    in every issue!
    hope what ive said has helped!
    my opinion: BUY IT!
