Sony KDL26S 2030 Green Screen
John Brown
I have had this lcd for 2 years now and I am delighted with the performance through the freeview. However, whenever I attempt to play a dvd I can only see a green image. I have double tested scart cables, dvd player with no resolution to the problem. I settle for watching dvd'on another set but that is a bit limiting! Any ideas?
table manners
Established Member
have you pluged the dvd player to any other tv's.
You say you have checked the scart leads but its still the same.how did you check them?
can you see a picture but its all green? that somtimes happens if the scart has a faulty pin or a componant cable is connected with the wrong colours.
I need some more info.
John Brown
I swapped scart leads with no effect and the DVD player is fine when connected to my Sharp LCD. When I was connected through a Sky box at my last house I could get a full RGB picture, as soon as I tried to connect directly to the TV back came the picture with only its blue and yellow components.
I tried speaking to Sony and they were of little help.
table manners
Established Member
Well sounds like the tv then.its back to who you got it from then,as I cant think what else it could be.soz
SVS Prime Wireless Pro Powered Speakers - Review Coming Soon
