jimg
Established Member
- Joined
- Jul 4, 2004
- Messages
- 981
- Reaction score
- 156
- Points
- 220
So you turn on NFC? or is there another menu for mirroring?
On Android under Settings, Screen, Cast Screen
On the TV chose Mirroring
Here's googles version of what jimg just said.So you turn on NFC? or is there another menu for mirroring?
Might be a good idea to give Jl a quick email, that way you have a return email from them about it John, .
Cheers gents.As far as I recall fella I think you just need to give your Bro the order details / number and that's it. I don't even think you need to phone JL to update the details to his.
Though don't quote me on that!!
Everybody got a bit of banding/DSE visible on the England game?
DSE? Damned Suarez effect......yes!Everybody got a bit of banding/DSE visible on the England game?
Is the banding and DSE worse than on the 829?
Nobody can answer that question.Is the banding and DSE worse than on the 829?
I went back and had a look at the settings, and now I'm trying Warm 1 as a middle ground between Neutral and Warm 2. I found clear white to be a very small and subtle change under Cinema 2, almost like a fine tuning setting between Neutral/Warm 1/Warm 2. It's certainly not enough to make a Warm 2 do whites that are not yellow.
Cheers gents.
Got home and fired a tweet to the and got a reply asking me to call them.
Do that tomorrow. Far too tired today.
Edit: Will fire them an email when I wake from my nap. Much easier and it's done then.
No. Don't do that.Funny - I'm another one who's just did this. After a week of neutral I thought I'd give warm 1 a go. 2 days I've been using it and it appears better. Not quite ready to jump to warm 2 though.
In regards to banding - I've noticed nothing. In fact so much so I never even knew what banding was until I searched for it. I will however go home and try to force out some banding with some grey/white images to see how badly my screen is affected. The fact that I've not noticed probably indicates it's very minimal.
Setting gamma to 0 is the obvious one that comes to mind.I'm finding dark scenes a little too dark, can anyone suggest some setting adjustments?
I've basically took the settings from here and applied to my screen, I have then adjusted them a little here and there but nothing major. I just find dark scenes a little too dark.
