where is the back button? i don't see on on my remote?
Precisely.
I think 'terrorist' is playing his part very well! LOL
Am i correct in saying you have to have motion switched off to be able to get 1080/24p on the w5500? Also is there a setting for 24p or is it automatically switched?
thanks
wolfy!!!!
Precisely.
crawl back into your hole and check page 13 of the user's guide. there are two buttons 'digital' and 'analog' described.Precisely.
I think Alsina means the toggle button which allows you to go back and forth between two channels - it's the one below the 9 here http://www.trustedreviews.com/images/article/inline/5199-remote.jpg
The 5500 remotes have a back button but it doesn't let you go both ways - you can only go back.
Just got my set and had a couple of questions (I've tried searching but can't find a way to do these) -
1. How do I move the Information bar down versus on top of the screen? I find it really annoying to have it at the top.
2. In SD how do I navigate back to the channel I changed from? Doesn't seem to be a back button on the remote.
Any ideas anyone?
Please help if you know...
[20] DIGITAL - press to display last watched digital channel
[21] ANALOG - press to display last watched analog channel
(both descriptions translated from my language)
So, moving on from personal insults, what you are suggesting in response to the question from lonetrooper is that the 'DIGITAL' and 'ANALOG' buttons on the remote control act as 'BACK' buttons. In other words, if I am watching digital and am on channel 1 and then switch to channel 3, if I press the 'DIGITAL' button on the remote, it will take me straight back to channel 1. Must say I've never tried those buttons for that purpose, but will do so today and report back.
Confirmed today that there are no 'BACK' buttons on the W5500 remote or any other buttons which offer this function.
My 46W5500 is back at sony now, they're checking out the complaint I have about the backlight bleed. I half expect a response "sorry? backlight bleed? no such thing, its perfect", then have it returned with the problem still blatently apparent.
Hopefully not. I wouldn't mind if it were fixed. You can see the areas where it is badly effected seems to be perfectly symetrical, as in where screws are holding the panel in place.
One question I have for everyone, is about some other issues I noticed with my set..
A: Ghosting. Very bad ghosting effect when black writing had say a grey background. This could be partly resolved by changing modes, but the ghosting was pretty bad. Anyone else plugged their W5500 into a PC as a monitor notice any faint ghosting?
B: Brightness dimmed on the edges. About 1cm around the very outside of the screen, the brightness drops out slightly. Noticed this when I have a white picture. Anyone else able to test theirs out?
Really hoping to just get the $ put towards the Z40 at this stage
For those of you worried about the backlighting issues, if it's any consolation I traded in my SonyW5500 for a new Samsung 7020 LED and the bleeding from the corners is much, much worse! Still love my new TV though!
Hello to all in this forum - my first post as I have just bought a kdl37w5500.
I usually post in the dphoto forum and my question is partly to do with pictures.
I have had no bother showing a slideshow from a USB stick but does anyone know if it is possible to have music at the same time from another source (ie not the USB stick) ? If so how?
Many thanks
