Sony KDL-S32A12U mains cable
Discussion in 'Cables & Switches' started by PJM007, Mar 26, 2006.
  1. PJM007
    PJM007
    Hi, does anyone know how long the mains cable for the above mentioned set is ?
    I want to wall mount it but not sure if plug will reach the the socket.
    Cheers.
  2. Dean25
    Dean25
    Aug 7, 2005
    135
    Reading
    +8
    Hi, you're best bet would be to ask you're dealer where you bought it from, or contact sony and ask them how long the cord is, if the cord is too short and want something that isn't bulky or ugly, get an iec plug and cut off the supplied plug and fit that and make/buy you're own iec lead to the length that you require, one word of warning though only cut off the plug on the tv if it is out of warranty!, as if its still under warranty and it goes wrong they may query why you took the plug off!
