Question Sony KDL-43W805C - no sound from optical out?
Discussion in 'Sony TVs Forum' started by FaxFan2002, Apr 29, 2016.
  1. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,477
    63
    Andover
    +169
    Hi All,
    Recently setup a Sony KDL-43W805C with a YAS-105 soundbar in the bedroom. Now, I'm 100% sure I had the optical out setup and working, but now it seems to have stopped.
    I've taken the optical lead from the back of the TV and plugged into a CD player and it works fine, so it would seem the TV has lost this ability or I'm missing a trick somewhere. I've tried auto1, auto2 and PCM settings in the TV all with no joy.
    Anyone else got a similar setup?
  2. JayCee
    JayCee
    Jan 20, 2004
    22,857
    Lanarkshire
    +2,425
    Do you have a red glow at the end of the lead that you would plug into the soundbar?
  3. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,477
    63
    Andover
    +169
    It certainly does, however I have found the problem.
    The TV volume was on mute which also muted the optical out, turning off the mute and the sound bar (and TV) came to life. Turned the TV volume down to zero and just the sound bar was active. Obviously.
