Sony KDL-40W4100 NTSC but want to use with Sky Box
Discussion in 'Sony TVs Forum' started by safesurfer65, Jun 8, 2015.
  1. safesurfer65
    safesurfer65
    Oct 5, 2009
    Hi all
    Hope someone can help. I've just aquired a US model Sony 40" LCD TV, model no. KDL-40W4100. Its a fair old vintage but still seems to work and would have been expensive when new. When I plug in my Sky box its says unsupported signal. I presume this is because its NTSC and not PAL compatible. I can plug in my gaming PC via HDMI port and it works fine. Is there an easy way to convert the Sky box signal to PAL via converter cable etc ?
    Mal
  2. hodg100
    hodg100
    Reviewer & News Writer
    Aug 8, 2005
    14,105
    3
    4
    +4,467
    You could probably get something cheap and cheerful that will convert the 50Hz signal to a 60Hz one but don't expect the results to be pretty; motion will be very choppy indeed.
    You could also spend a lot of money on a video processor (£1300ish) that would do a much better job but then you could buy a new TV for that so you'd be barking to do so.
