Sony KDL-40HD1080 LCD - more details?
Discussion in 'Sony TVs Forum' started by washingtonirvin, May 2, 2007.
  1. washingtonirvin
    washingtonirvin
    Mar 14, 2007
  2. stormy
    stormy
    Dec 16, 2004
    2,983
    +304
    Looks like no "Motion Flow" (100Hz) from that slide as the D3000 slides show "Motion Flow" as a logo/graphic feature.
  3. Pallaris
    Pallaris
    May 25, 2002
    180
    +11
    That would be dissapointing cosidering it's likely to be a much more expensive set as well. Perhaps too early to say. Is this supposed to be the X's successor or will there be two full HD panels again this yr?
  4. kourosh
    kourosh
    Feb 6, 2005
    14,919
    Portsmouth
    +1,108
    your right there will be no motion flow,on this set only the "D" range will have this feature:smashin:
  5. kourosh
    kourosh
    Feb 6, 2005
    14,919
    Portsmouth
    +1,108
    Its looking as this model will be a budget 1080 panel,so it will be bellow the X and W.
    The current X and W are to be updated in around Oct time:smashin:
