Sony KDL 32W653 / KDL 32W654
Discussion in 'Sony TVs Forum' started by VHS, Aug 22, 2013.
  1. VHS
    VHS
    Aug 22, 2013
    Just wonder if anyone can advise me of the features and functionally of the DVB-T tuner in the KDL 32W65* model from Sony
    Is is possible to tune just to a selected transmitter (I live in an area of 3 transmitter overlaps and its a right pain!):rolleyes:
    Also can you hide channels
    And change the channel order
    If hiding channels and changing the channel order worked like the old Sony VTX-D800U Freeview Set-top box that would be superb!
    Thanking in advance
    VHS
  2. Ianpb
    Ianpb
    Apr 6, 2008
    5
    London
    I found that it is possible to select different transmitters, but only after the set-up stage when it gathers in all the channels. At that point you are given the choice. I did look to find if this can be done at a later stage but couldn't find any facility for that.
    I live at the western edge of Greater London, and found that after tuning I had a choice of three transmitters. Strangely, the London selection had weak signal strength, so I had to retune and then selected the 'Berkshire' option, which works well. So maybe you will have a similar experience with deceptive names.
    I also found that the channels detected from the transmitters I rejected are saved to higher channel numbers.
