New Patreon Tier and Early Access Content available. If you would like to support AVForums, we now have a new Patreon Tier which gives you access to selected news, reviews and articles before they are available to the public. Read more.
Hi, i was looking to buy something to enhance the sound quality of my Sony 32v2000. Has anybody got a cinema or speaker set up they would recommend? Looking to spend up to 300 pounds.
I have been looking at this too for my 40V2000. The TV is just lacking any bass, so I was looking at the Toshiba sub that is designed to fit onto the back of the Toshiba LCD's. Not sure whether this would work, but it looks as if it could be an option.
Buying a £1700 TV and not spending a little bit for a surround sound system to couple it with seems like a waste to me. Especially since you can get a perfectly decent SSS for a couple hundred quid these days. And it adds SO much to the experience it's not even funny.
I got a Yamaha AV 57 pack - was an RX-V357 amp with the NS-P110 speakers. It was about £180 and I would recommend it, but they have stopped doing them now.
Another make? Why didn't you notice this before you bought it?1200/1440+300 pounds you are joking and lets not discus the PQ , .better to be had out there.
Actually I think LCD TVs having pretty average built in speakers is now the norm across all brands - and it's not very easy to check for sound in a loud store anyway.
as it (a) fits into your budget (b) matches your TV (c) has excellent sound quality for the price. Also has the benefit of giving you an extra HDMI input as it has a built in HDMI switch
