T
terrorbite
Hi. I bought a 32" Sony KDL-32U2000 LCD tv, after reading glowing reviews of it on the net.
Now I know the U range is Sony's cheaper one, and I know that standard def broadcasts have to be upscaled to the resolution of the TV (it's HD), but the picture quality is terrible. Playing games (granted on the original xbox, without HD cables) is an awful grainy experience too.
I was flicking through the channels, and stopped on The Hits, and the picture was just a mess and I don't think it was to do with the digital signal (we don't have any problems with that).
Maybe I'm just being picky. Does anyone else have this tv? I am happy with its brightness/contrast and I can accept the slight blurring during fast motion. Its mainly "noise" around images - like when you save a jpg image at low quality - that I have a problem with.
Edit: Also, if you do a price comparison search, you'll notice digitaldirect.co.uk is a lot cheaper than other sites. It seems they do this by sending out european versions of the tv. It came with the standard UK plug etc, but there were no english instructions with it. Its not really a problem, and you can download the english pdf manual from their site if you need it (which I didn't), but still. It also says assembled in slovakia, as opposed to the english manual version which I think is made in spain. Are they ripping their eastern european customers off with inferior components?
