Sony KDFE50A12 Up And Running
Discussion in 'General TV Discussions Forum' started by oscarmadfish, Nov 5, 2005.
  1. oscarmadfish
    oscarmadfish
    got my sonyKDFE50A12 up and running :)
    stand and telly look good :thumbsup:
    sky using RGB scart looks good much better than my last 42 plasma :thumbsup:
    DVD using denon1920 upscaling to 720 looks very good indeed :thumbsup:
    as for settings DVE did not make much difference nor did THX
    just stick with the settings lee put in the other thread and then adjust to your own preferences
    always happy to take tips from you folks so post away
  2. oscarmadfish
    oscarmadfish
    found my first bit of slight annoyance :mad:
    while it does 4.3 etc it wont switch auto i have to do it manualy :thumbsdow
    the best it will do is smart mode which zooms in to fill the screen :rolleyes:
    not that smart me thinks :rotfl:
    its only minor otherwise happy as a pig in sh it so far :thumbsup: :) :smashin:
  3. logiclee
    logiclee
    Aug 9, 2000
    1,762
    116
    Notts, UK.
    +782
    Make sure you have Auto selected in the menu's
    Smart Mode half streches and half zooms the picture, you can then move the picture about using the up and down arrows on the remote.
    Lee
  4. oscarmadfish
    oscarmadfish
    thanks lee
    i set auto in one and 4.3 in the other and thats done the trick
    have to say this set is fooking good value for money :thumbsup:
  5. leeboy2k3
    leeboy2k3
    Jan 20, 2004
    237
    walsall
    +6
    what is the contrast ratio on this tv? and how does the set compare to the sammy splh7?.. contrast, lumen output for daytime viewing, connectivity etc?
    finally I dont notice rainbows unless I watch black and white stuff in the dark like sin city, so please no silly rainbow remarks or ill go fetch rod jayne and zippy!
    lastly what is the motion threshold on it like?.. example pro evo5 pc ver is a good test at 720p, oh and dare I say it black levels versus the sammy, is it worth the switch or should I wait for the new dlp's next year..phew cheers!
  6. logiclee
    logiclee
    Aug 9, 2000
    1,762
    116
    Notts, UK.
    +782
    The Sony has excellent contrast, have a look at the settings thread and you will see most people set the contrast below 50% for home viewing.
    Motion blurring shouldn't be an issue, I enjoy motorsport and even very fast moving backgrounds are not a problem. It's certainly better than the oil painting effect that is visible on some DLP's.
    Comparing the Sony against the Samsung "7", the Sammy does blacks better and the picture is sharper but the "7" does have a list price that is over £1000 more than the Sony.
    Compare the Sony against the Samsung "6" models evens things up. The Sony has a slightly more vibrant picture and picks out colours better but the Samsung does dark detail better. All IMO of course.
    The Sony isn't bad at blacks, it's better than any direct view LCD or Plasma I've seen, although I've not had a look at the new Pioneers, it's just not quite as good as the best DLP's.
    Lee
  7. oscarmadfish
    oscarmadfish
    whats everybody use to clean this type of screen ???
    soft cloth and warm water for me
    anybody got better options ???
  8. kourosh
    kourosh
    Feb 6, 2005
    14,972
    Portsmouth
    +1,125
    thats fine just luke warm water and soft cloth,dont ever put any spray polish on these screens
