Sony KDFE50A12 CONNECTING PC TO TV
Discussion in 'General TV Discussions Forum' started by Giulio, Mar 16, 2006.
  1. Giulio
    Giulio
    Dec 13, 2005
    38
    Hi all
    I know that this has been discussed at length in the forum but could someone please point out any obvious problems a first timer like me will fall in to, connecting up this TV to a pc using the VGA port.
    I would be very grateful for any input/tips etc
    Giulio...thanks
  2. unterwasser
    unterwasser
    Jan 11, 2006
    129
    Northallerton
    +18
    I'd no problems connecting my pc. Had to get a Male-Male VGA cable but apart from that connected straight away and adjusted automatically for the screen resolution.
    You'll have to get a cable to connect your soundcard as well, unless you're planning to use an external amplifier and/or some other speaker configuration.
  3. CaPo
    CaPo
    Dec 11, 2005
    941
    43
    Glasgow
    +188
    Can you get a 720p signal over vga so it uses the fullscreen of the tv or does it stay in a 4:3 format like im getting just now using s-vid?
  4. Sy1441
    Sy1441
    Apr 10, 2005
    4,487
    Glasgow
    +284
    You can change that screen resolution to custom settings using a program called powerstrip
  5. gkinghrn
    gkinghrn
    Feb 26, 2006
    175
    +15
    My dell Laptop with VGA cable just didn't want to know it..Grrrrr.. I suspect the usual problem with external Video and laptops..I imagine th eTV is fine...
    (And me being an IT guy too!!)
