demonsword
can anyone tell me if there is a fix for the noisy fan on the sony kdfe5012u lcd rear projection tv? or is the noise normal,,,also is the fan on the sagem dlp projection tv's as bad? thanks.
demonsword said:can anyone tell me if there is a fix for the noisy fan on the sony kdfe5012u lcd rear projection tv? or is the noise normal
demonsword said:also is the fan on the sagem dlp projection tv's as bad? thanks.
porkamoo said:...the Sagem was at least 3-4 times louder and was more of a buzz than a hum which I found much more obtrusive.
