Sony Kdfe-50a12u
Discussion in 'General TV Discussions Forum' started by doodles, Mar 20, 2006.
  1. doodles
    doodles
    Mar 20, 2006
    424
    +25
    SONY KDFE-50A12U
    Hi guys, how do you get freeview channels from this tv, is it through the normal tv ariel?
    also was considering this tv, is it any good...
    thanks
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,724
    Somewhere in South Yorkshire
    +6,298
    Freeview is received (always) using a standard UHF TV aerial i.e. the same fundamental type as regular TV. This TV has an onboard Freeview tuner so will receive Freeview without any external help.
    Providing of course you are in a Freeview reception area. Depending on where you are, and your existing aerial, you may need an aerial upgrade. This is due to a different spread of UHF frequencies used at some transmitters to those used for analogue (normal) TV.
    Is the TV any good? There is a massive amount of detail already on this forum. Most of it very positive.
  3. Kidwhizz
    Kidwhizz
    Mar 9, 2006
    75
    Ealing
    If considering the Sony 50" 3 LCD rear projector, might also want to have a look at the DLP rear projection, more expensive, but they have a better picture quality. LG, Samsung and Sagem (ok to very good in that order) all make these.
  4. doodles
    doodles
    Mar 20, 2006
    424
    +25
    Thanks guys..
    you mentioned samsung, seen this model: SP46L6H screen size(46"in)
    what do you think of it compare to the sony, which is better?..
    also alittle confused about this bulb thing which is in other threads,what exactly is that about?
    cheers
    doodles
  5. LV426
    LV426
    Jul 14, 2000
    13,724
    +6,298
    Bulb thing? LCD and DLP rear-projection TVs have a lightbulb in them rather like a slide projector does. Except that it's typically some sort of high pressure discharge lamp. These have a finite lifespan, and are user-replaceable. The lifespan is the subject of much debate, with different estimates being quoted from different sources. Coverage of the bulb by warranties and extended warranties is also open to some doubt.
    The long and the short of it is - you may need to replace the bulb (at a cost of somewhere between 100 and 300 pounds) sometime during the life of the set, depending on your usage pattern and the state of your electrical supply, and, if you buy with an extended warranty on the basis that the bulb is covered, get this fact in writing.
  6. Gareth33
    Gareth33
    The Sony is the best TV of all time.
    Its that simple.
  7. gkinghrn
    gkinghrn
    Feb 26, 2006
    175
    +15
    Actually IT IS WAY BETTER than that..:D
  8. Gareth33
    Gareth33
    No your wrong, its A LOT BETER than that !
  9. Gareth33
    Gareth33
    Or BETTER even !
