Sony KDEP42 XS1
Discussion in 'Plasma TVs' started by johnryall, Dec 8, 2004.
  1. johnryall
    johnryall
    I've recently taken delivery of this new plasma from Sony, and am very pleased to report that the picture quality is absolutely stunning, both from its integrated Freeview tuner and also from a Toshiba DVD connected through an RGB enabled scart.
    One annoying problem has surfaced when watching a dvd - the picture will be replaced momentarily with a blank screen with a message about "software download ... checking broadcaster " or similar. There is the ability to switch this function off in the features menu, but it makes no difference.
    It does seem very strange that it happens at all in a/v mode - has anyone experienced a similar problem or is able to offer any guidance other than disconnecting the aeriel?
