Hi all, has anyone seen this plasma and if so, were you impressed. Better still, has anyone got one ? I can only find out that it got 5* from What Hi-Fi in October issue, which I didn't see.
Looks to give a very sharp picture. It is almost as big as a 42" though, and it doesn't have PC input if that's a problem. I think it uses an ALIS panel so has varying degrees of future compatibility.
Thanks 4 that Toaster...But I wouldn't be using it with a PC...especially with the burn in problems on Plasma screens...I'll have to take a look if it's a big as you say it is though
With it's wing-type speakers it's about 115cm wide. Compare that to the PE30's 104cm, I guess it's not much but most people going for a 37" are going for that size because 42" is too big - not that it's too expensive.
Time to get the tape measure out then...and that's exactly why I'm going for a 37"....but the Pany is not as future proof..and there are no other options at the moment in 37".
