Sony KDE-P37XS1 and KDE-P42XS1
Discussion in 'Sony TVs Forum' started by deluk, Oct 6, 2004.
  1. deluk
    deluk
    Mar 12, 2004
    14
    3
    Leeds
    I am wondering if anybody can help me ?, I had a Sony KDE-P42XS1 delivered last week and have a couple of questions if anybody has this or the 37inch model :-
    What settings do you have your plasma on, contrast, brightness etc etc
    Does anybody know how to put the plasma into a factory mode so i can see how many hours the plasma has been on for as I concerned this tv wasn't brand new when i recieved it.....all the channels were programmed in and they are not supposed to be !!
    Cheers for all your help
    Del
  2. FEBABE
    FEBABE
    Del
    I have the 37" version and have turned down the contrast and brightness to 35 for running in. The movie setting looks about right to me with contrast/brightness (can't remember off hand which is still adjustable) turned down to about 50.
    Don't know how you get in the factory settings, can't say as I've seen anything, but I can tell you box was sony sealed and there were no channels programmed when I got it.
    F
  3. deluk
    deluk
    Mar 12, 2004
    14
    3
    Leeds
    Thanks a lot FEBABE,
    Just rang the sony centre where I bought it and they said they will replace it with another just in case this was not absolutely brand new !!!
    Cheers for your help I really appreciate it
    Del
  4. nheather
    nheather
    Oct 6, 2004
    16,913
    167
    Horsham, West Sussex
    +6,168
    Sorry for jumping in, but since you have the Sony KDE-P42XS1, can you tell me whether the speakers are detachable or not.
    Thanks,
    Nigel
  5. FlyingRabbit
    FlyingRabbit
    Sep 27, 2004
    26
    Droitwich
    Hi Nigel...I have the 37" being delivered this morning (hopefully)..I can tell you that the speakers are NOT detachable.
  6. mandeep_sv
    mandeep_sv
    Thats a no go.........they are not unfortunately.
  7. rover
    rover
    Jun 2, 2003
    60
    9
    Norfolk
    +12
    I am about to buy one of these. Is there any reason (apart from this forum's aversion to ALIS) why I should not?
  8. Leerca
    Leerca
    Sep 15, 2004
    7
    Go for it rover!! I've had mine (KE-P42XS1) for two weeks now and its fantastic. I'm watching movies with Sony 585 dvd-player (component leads+progscan) and tv thru digital broadcasting. I'm really pleased with my choice!
