jamez21
Here’s one for all you OLED lovers, came across this not sure if they’re legit what do you think -Sony KD-55A1 OLED TV - Sony OLED 4K HDR TV - 55 Inch Sony OLED
How about £2249? Only got til midnight, use code thurs10 !
Doesn’t work
Of course not, same panel that LG use and it has a worser OS.The LG BC/C7 can be had for around £1.5k, don't think Sony A1 is worth £1k extra.
The LG B7/C7 can be had for around £1.5k, don't think Sony A1 is worth £1k extra.
Yeah but still most who buy oled will have or will buy a separate sound system, most people went for the sony because of better picture processing but I hate android OS with a passion.People keep forgetting that you pay more for a Sony because of the acoustic surface. It's the reason I picked it over the B/C7. Perfectly fine to go with the LG if you have a separate sound system.
It can but most people who go for the Sony do so because they want to use the acoustic surface speakers built in.Just looking at this tv and wondered if a sound bar can be used with it?
First world problems: having to press an extra button!Isn’t the E7 more of a comparison to the A1, which brings the price a lot closer. From my perspective it’s good to have a decent built in sound on the tv because I don’t always want to fire up the av kit just to watch Corrie St
Not even that if you use a Logitech Harmony remoteFirst world problems: having to press an extra button!
Might have had the budget for one if I'd won a 9002 rather than having to buy one!!Not even that if you use a Logitech Harmony remote
